Wasn't sure where to put this but seemed like the best place. When I built my pool, the designer recommended I get a vacuum pool cleaner while I wanted a robot. We settled on putting the plumbing in but not buying any of the vacuum equipment. So I have a pipe running from my pool back to the pad that isn't hooked up and is just capped off at the pad. In the pool there is just a hole with threading and it is not capped, water flows freely.
Should I buy and screw in a cap for the hole in the pool or should I just leave it open. It seems like there is probably stagnant water in there so I just poured a whole bunch of chlorine down the pipe by the pad but I'm worried if I leave it open that it is a potential source of algae in the future. Thoughts on if I should be concerned or just let it be?
