The snow is still coming down here, but I'm organizing everything I need for an early spring install. The wife and kids are really anxious about getting the pool put up and together, since we got our pool delivered late August (when we ordered in mid-April) in 2020. As 2020 was shot, so going over everything I need in order to be prepared as soon as can be.
I remember having a design for running pvc pipes, but now I can't find it anymore. I drew up a diagram on how I think I can make this work. I remember being worried about how to drain water from the pool. I wonder if my new design will work, or if it's not worth it at all.
The orange circles/blobs are unions, the blue circles/blobs are shutoff valves, black is for skimmer run, and red for return run. I'm undecided on the solar run yet, but want to plan ahead just in case. I was thinking that "lowest drain point" would be slightly angled downwards upon teeing off the main return line, with a shutoff at the end. This would allow me to direct drain water where needed. (My yard has a slight hill where I can have some pipe and shutoff come out of without being in the way of the yard).
If doing the solar run, would this suffice, or does it need a shutoff on the return side of the solar? I don't know if there is a problem with pumping return water and it going up into the solar return side?
This should hopefully allow me to easily blow out the lines for winterizing, starting with the skimmer side blowing air through the pump/filter, and through all the open solar/return lines (including drain line). Is this correct?
