Hey everyone since this is my first post let me introduce myself. My name is Doug and I am from the St. Louis Missouri area. I have done alot of reading on here and decided to tackle building my own pool. I have the slab poured and the first 3 courses stacked up. It's (past) time to get my plumbing fittings ordered and I am looking for input on skimmers, returns, lights and a wall drain that works well with block construction. I understand that I may just have to make them fit but there may be some that are easier than others. Any input appreciated.
This will be a vinyl liner 19x28 with a 54" water depth throughout. Vertical rebar every other course, all cores filled with concrete and bond beam at the top of the wall. All rebar also to be bonded.
Plumbing placement advice needed as well.
Attached is a proposed plumbing layout for your critique as I am winging it here. LOL
Also do you think 2 lights are enough? Planning on going LED. Sorry so long on the first post. Thanks for any advice given and thanks for looking.
View attachment Pool Plumbing.pdf
