PH with Liquid chlorine
cledee
403
North East
This will probably need to go in the agree to disagree section, but my question is if Liquid chlorine has a PH between 11-13 and you are keeping your pool Chlorinated between 4ppm and 8ppm depending on your CYA wouldn't the PH be slightly affected by Chlorine since you are always keeping your pool Chlorinated around those ranges. So for example if your pools PH is 7.2 without Chlorine but then you add enough for 4ppm-8ppm, wouldn't your PH be higher after the chlorine addition and going forward since you are maintaining that range?
So, yes and no. The initial addition of liquid chlorine does in fact raise the pH of the water, but as it is used up in the water the pH comes back down such that the net effect of adding bleach is zero.
So if you maintain the FC level using liquid chlorine, because you're adding bleach as it is being used up, your pH will remain virtually unchanged by the chlorine. It will probably drift, though, due to other factors like outgassing.
Reactions: cledee
I am no chemist, but I have stayed at a Holiday Inn. No never mind that attempt at being funny.
I do believe and through years of adding LC that a full gallon, 128 oz, poured into 25k gallons would have only a negligible bump up of pH.
  • Haha
Reactions: cledee
So if your pool was 7.2 ph prior, adding 1 gallon may bump it up to 7.25 or 7.3, but nothing significant?
Right, but by the time that gallon's worth of FC has been used up, the pH will have come back down to 7.2. So if you add one gallon each day to maintain your FC level, your pH may fluctuate +/- 0.1, which is completely fine.
Reactions: cledee
