t's been 4 months and I just purged my hot tub and getting water rebalanced. It's been overnight and I have run it umpteen times. Used Dichlor to get Cl to 12. ('m gonna use Dichlor until I get CYA to 30 and then switch to liquid Cl). I checked and it was at 11.5 two hours later after initial fill. This morning the Cl was 6.5. Cal was at 150. TA was at 60. All is well....until I check my pH. IT is purple. 8.0 or higher. I then proceeded to add the "Acid Demand". I added one drop and the pH dropped to the really yellow. 7.0 to 7.2. I decided to add 1/2 oz of muriatic acid 34% to my 355 gal of water. Waited an hour and go back and check pH and it is till 8.0 (purple).
You know, I thought after a year I would be an "expert" but I am at a loss. Is the fact I am using Dichlor causing this problem. I use the 871 powder test for the Cl. What am I missing?
