So I have a one year old liner that has been leaking for sometime. Like since right after they installed it last year! Fast forward to this year, they come out, fix a leak around the light, find a small hole that was still below the water line. Lots of water under the liner, they pull liner loose, put pump under liner and remove water. They start refilling the pool and 12 hours later the liner is floating all the way up to the waterline. They drain the pool again, pump out the water under the liner again. Go looking and find a big tear in the liner so they fix that. They then go to the deep end and find literally hundreds of pinholes! They say they have no clue what put the pinholes there!
I think I might have an ant or termite problem under the liner. We have no other idea as to what it might be other than ants or termites. They have ordered a new liner to be installed. But I want to put something under the liner before they install the new one to stop the ants or termites. What would you suggest that will not hurt the liner from underneath?
