Pentair pump/heater problem
Lanalvk
1
New Jersey
Hello.
We have our pool installed over a year ago with Pentair equipment
Since then we had priming alert issues that were fixed by our pool company
Couple of days ago we woke up facing another issue
The ScreenLogic application show high temp ranking from 104F to 122F on and off
The pump will start but jets are not working, so the pump will then turn off, there is also low flow red light and blinking red light for the salt on the cell. Do not see any pressure going up on the filter
Can anyone recommend a solution?
Our pool company are not helpful
Thanks
Welcome to TFP!
Were you able to get your equipment working? It sounds to me like you may have an issue with the position of the valves. I don't know much about Screenlogic, but if you still need help, let us know. Maybe a few photos of your equipment pad showing the plumbing and valves will help us out.
Reactions: DavidArmenB
