So I just swapped into a new CCP520 filter shell, but when I re-attached my existing plumbing to the inlet, I have a slow leak no matter how tight I set the attach fitting (outlet connection is just fine, BTW). Should I lube the o-ring? If replacing the o-ring is the better answer, would anyone have a part number for it? Thanks!
