Great write up by
@bradgray. I don't know the IC lite, so I'm just chiming in with some general automation advice.
Brad seems to know a bit more about your pool than the details in this thread. Are you building a pool? Do you have a build thread here? Or is your pool built, with some or all of the equipment you list already purchased and installed?
Anywho, I'll be a bit more "devil's advocate" than Brad. I will be happy to share the long-winded version if you care to know, but a UV system is completely unneeded for an outdoor pool. This is a money-grab by your builder (or whomever is advising you get one). Do not buy that.
And since you expressed to your builder/seller the notion of automation, the SuperFlo is the wrong pump, period. That is an odd recommendation. Get an IntelliFlo. Insist on that. You want to be able to program multiple pump speeds and have full access to each speed, and the ability to
change each speed, from your automation interface, including remotely (away from home).
If you've got the breakers for your pool covered, than I suppose you don't need an automation solution for breakers, but if you have a way to run 30 amps to your pad, you'll be happier with the breakers on the pad, and housed in the same cabinet as the automation. Brad refers to this as the power center. My biggest regret of my purchase of an EasyTouch is not having the integrated breakers. Second regret was not having the integrated SWG transformer.
I'm happy with my EasyTouch, but I had to have it upgraded to an EasyTouch 8, because the "lite" version of EasyTouch was awful for my eventual use case. And this is mainly why I'm jumping in, to get you to think in terms of your
future setup,
not the one you need right now. I have a simple pool, but I'm an automation geek, and eventually found a use for six circuits. And one of those is not my pool light yet, so I really have a use for seven.
Keep in mind that you can automate more than just your pool equipment with a pool automation system. My yard is fully automated with probably a dozen gizmos. I use a dedicated home automation system for all that, but if you don't intend to run something like that, you could use your pool automation system for other devices, and have remote control of your yard from your phone. Examples include:
- Yard lights
- Garden lights
- Fountain(s)
- Bug zapper
- Outdoor speakers
- think anything that can "plug in"
I also use extra pool automation circuits for
- A high-speed skimmer mode.
- A dedicated suction-vacuum mode (I have a pool valve actuator for that)
- Solar heating (I have a second pool valve actuator for that)
- Gas heating
- Pool fill automation
- Freeze protection
- Pool acid injection
And I have an SWG.
Point being, just because you think you now have the use for only one or two relays, once you get the automation bug, that number would change drastically.
So think now about what you might want to do with your system. Asking what each model of automation can do is one approach, but the wrong one IMO. You should be asking yourself what you want to automate now, and in the short- and long-term future, and then find the system that can do that. Here's an example list, modify it to fit your use case (this is mostly me projecting, but I never considered these things when I chose my system):
- I want to have a high-speed skimmer mode to clean my surface quickly just in front of a pool party
- I want to have a quick vacuum mode, in addition to my daily cleaning schedule, to do an extra clean just in front of a pool party
- I want to heat my pool with a solar heater
- I want to heat my pool with a gas heater
- I want my automation system to know which of my two heaters to use at any given time for best efficiency
- I want to be able to control the schedule and the output level of my salt water generator (something, BTW, that changes many times throughout the year)
- I want to automate pool acid dispensing
- I want to be able to control:
- my pool lights
- my patio lights
- two circuits of garden lights
- a bird bath fountain
- some bistro lights
- I want a couple of circuits for expansion, for things I've yet to think of
So even with a "simple" pool, you might actually have a need for a sophisticated automation system (or maybe you won't).
And finally, EasyTouch, I think, is now decades old. The add-on ScreenLogic system, which you would need if you want to run your pool from an iPad, your phone or computer, is also that old. Pentair does keep the mobile device interface for ScreenLogic somewhat current, but not the computer interface. That is all but officially abandoned. There is no browser-based interface, it is a kludgy Windows interface that was once ported for Apple computers, but that too was abandoned and no longer even runs on the latest Macintosh OSes.
Their more recent offerings are all based on IntelliCenter. I don't know much about IntelliCenter, but I understand it has a browser-based interface. It is definitely where the Pentair focus is now. I imagine were I to buy today, I would be looking at the new tech of IntelliCenter, and not the well worn (out) tech of EasyTouch.
So, for me at least, buying the older, "lite" EasyTouch was my single greatest pool equipment purchase mistake. I should have gotten an EasyTouch 8 with the integrated circuit breakers and SWG transformer. And don't get me wrong, EasyTouch is a good system, and seems to be a Pentair staple, but it hasn't been upgraded in forever, which indicates to me it's not going to be (that's pure conjecture, but a somewhat educated one).
PS. I cannot imagine running a pool without automation, but especially not without a salt water generator. You are very likely going to want one, and if you're going with Pentair equipment and automation, you'll want a Pentair SWG, and one that is fully integrated into your automation system. Think that through now.
I suggest you build your automation wish list first, then download the owner manual for any automation system you are considering, and pour over those manuals until you are crystal clear on the best system for your future needs. It's what I didn't do, and still regret. I let someone else, who knew better than I did, select my automation system, and that's where I went wrong. I should have done my own due diligence. Starting at TFP is a great first step, but shouldn't be your only. And from the sound of it, your builder is not a trusted resource for this decision.
Continue your research. Continue to ask questions here. Others that know the IntelliCenter and the Easytouch will no doubt chime in.
