Hi all! New pool owner here with 2 questions.
1. Shouldn’t the water level always be below the top of the skimmer? My understanding is the skimmer works to skim and clean the surface of the water, so if the water level is higher than the top or the skimmer, it can’t and won’t do it’s job.
2. Where the heck is the overflow mechanism? I’ve been instructed to vacuum it to make sure it’s not clogged (or to unclog it if it is) and I have no idea how. I have a fiberglass pool, so I assumed the overflow opening/pipe would be in the skimmer but I don’t see it.
I did email the pool company about the water level and lowering the overflow and their response didn’t really make sense to me (English is not their first language, please be kind). This is what they said:
“If the water level of the Pool was good and the overflow was working fine Prior to this Rain Season , you don’t need it to adjust , however the overflow sometimes get clog , you need to cleaned every 2 months or so, you can used the vacuum to suction the Pipe, if we cut the overflow when dry season came we need to adjust one more time because the evaporation is intense as well and you are going to loose to much water on the pool”
Thanks in advance!
Thanks in advance!
