I hope I'm in the right location.
New pool owner and we have several days of freezing weather coming. Last year we were without power for 4 days and I didn't have the pool then. I've since setup my home to have my new generator to power my electric panels and have my inground propane tank to fuel my generator. So I should be able to keep the pool running. This leads me to a few questions though.
Do I have to run the booster pump as well?
I have a stone wall with 2 stone scuppers each with their own line from the equipment. The main pool pump provides water to them. The valves for the scuppers are at the equipment. Can I shut this valves off while I keep everything else running so the scuppers aren't running? Or do I want to keep the scuppers going?
But if things go south and I can't keep the pool going, are there additional things I need to do besides what I've listed?
-drain pump
-open the pressure valve on the pool filter to let air in and get some of the water out of the filter
Thanks for the help.
-drain pump
