Newbie, first test
loathe
2
Newport News, Va
Hey folks, I'm Tim. I live in the Hampton Roads area of Virginia, 8b. 8000 gal intex above ground pool
Test scores:
Fc : 35
Ph : 8.2
Ta : 80
Ch : 500
Cya : 35
Pool is reasonably clear with just a bit of green on one end.
I thought the pool math app would tell me what and how much to add.
Can someone kinda handhold me through this a bit?
Welcome to TFP Tim!
Can you confirm which test kit you're using?
Always round-up CYA to the next multiple of 10. That makes yours 40 ppm.
Did you use a FAS/DPD test kit for the FC result (reagent #s R-0870/0871)?
If you're seeing visible signs of algae, you need to complete the SLAM Process.
Maintain SLAM FC level of 16 ppm based on CYA level of 40 (FC/CYA Levels). Lots of brushing. Clean filter when pressure increases by 25%.
Please complete your signature. It'll help others help you...
I'm using the tf100 pro.
Yes, that number is FAS/DPD.
OK, On it! Will update!
Let us know if you need anything. Don't be afraid to ask! This is the hard part.. after you complete the SLAM, you'll find how rewarding it is to care for your pool the TFP way.
