Hi All!
First time pool owner here and soaking up (pun intended) everything I can read about pools at the moment. Coming here for advice and other guidance. I have read the Pool School as well as another site, Swim University cover to cover. I have included my pool info in my signature.
My struggle is with the pool store saying my levels were good, but then reading online learning about CYA and how it interacts with the effectiveness of how the chlorine works. To get things started, as of today...
(Poollogger.com Format)
I have omitted FC because I do not have a good way to test it. My current test only goes up to 7, which is too low for me with the CYA that high... I do have test strips and the FC tab shows 10ppm so I know I am high up there, where exactly, I do not know. I did order a K-2006 so on Wednesday I should have a pretty good FC reading. But between the test strips, and the other test showing over 7, I have a good feeling that I am in the "Good Enough" range right now. Water is clear.
We have a DX4 Dolphin, when we bought the house, it wouldn't power on. Did a little soldering and "The Kraken" is now up and running.
Now for all my issues and questions that I came here for, if things don't get answered here, I plan to ask in the respected categories in the forum in time...
1) Air leak, I know I am pulling in air through the suction side, when the Jandy valve is pulling from the Main Drain, one of the returns spits out air. Turn it to the Skimmer, and the bubbles go away (after I bleed air from filter dome)
2) I don't think the pump has enough power to push water to the roof. There is a 3-way Jandy valve that sends water to the roof or bypasses the heater. If I send everything up to the roof, it pushes all the air out and it works just fine. (Got the pool up to 95F) However, if I do half bypass and half to the roof, when the pump shuts off, it won't send water up on start up. I have to close the bypass completely, let it travel up, then crack the bypass if I want to go half. Is this correct? I do understand things in motion tend to take the easy way, so that would be the bypass.
3) Skimmer doesn't have a weir. So when pump shuts off, things just tend to float out. Looking at it, I can't see where one would attach to?
4) When is a pool considered unsafe? When is chlorine too high for swimmers? PH too low? Alkalinity? At what point if the test results are way off the mark do you stop swimming until its fixed?
5) Some stains on the wall. I know it's not organic because I tried the rub a tablet on it, and it didn't budge. I feel it's rust or some other kind of metal. It's not bad, I plan to work on this in the Winter months.
6) Not a problem, but our Lab LOVES the pool! Only catch is her fur loves it too.
Yes, I use tablets now, I understand that CYA is going to continue to be a problem but I do have a plan (I think)...
1) Use up my supply of tablets, I can't justify letting them go to waste.
2) Take care of the water swap... if its splash and fill or let Florida rain storms just fill up and me pumping it back down.
3) Switch to Salt or liquid chlorine
As much as I would love to start working on it now, I just hate wasting what I have.
I have attached a couple images below, the first one is a really bad job at photoshopping two images, in real life the pool doesn't have a seam in it.
Sorry for the lengthy intro post, just wanted to say hi and I look forward to learning all I can!
--Dan
CC | No Test Yet Target: < 0.5 | |
PH | 7.6 | 12 hours ago Target: 7.2 - 7.8 |
TA | 110 | 12 hours ago Target: 70-90+ |
CH | No Test Yet Target: 250-350 | |
CYA | 100 | 11 days ago Target: 50 |
Temp | 87° | 12 hours ago |
--Dan
