- May 18, 2023
- 97
- Plaster
- CircuPool RJ-45 Plus
I’m following the PebbleTec start up ranges which I will post below. Ran the TF Pro tests this morning. I’ve added about 26oz of muriatic acid per the pool math app. Time should lower the FC, right? Or should I remove a puck in the floater? And CYA pool math note says to add stabilizer - the pool start up guy put in 3 tabs. Will this raise over time or should I add additional stabilizer? Any additional insight is helpful.
PebbleTec start up ranges:
PH 7.0 to 7.4
TA 80-100
CH 150-250
FC 1-3
CYA 20-30
My Results:
PH 8.2
TA 110
CH 225
FC 4.5
CYA 10
Also adjusted my runtime:
Timer 1 - 2700rpm 7am to 9am
Timer 2 - 1200rpm 9am to 3pm
Timer 3 - 2700rpm 3pm to 5pm
Timer 4 - 1200rpm 5pm to 7am
PH 7.0 to 7.4
TA 80-100
CH 150-250
FC 1-3
CYA 20-30
My Results:
PH 8.2
TA 110
CH 225
FC 4.5
CYA 10
