I have a new 18,000gal, IG, plaster pool, spa with spill over, ozone system, SWG, Cartridge filter, Hayward system control, 2 speed pump (6 hours low speed and 4 hours high speed middle of the day, chlorinator set at 50%. Initial fill February 16, 2018. The builder added salt the first week which I have discovered is/was part of the problem I have been fighting. Water is crystal clear.
I have been having my water tested by a local pool service on their electronic system about 3 times/week. Initially, I was adding acid constantly trying to drive down the pH. The pH has finally settled into a less demanding pattern. Now I am working on the fine tuning...I think...until I had my water tested yesterday and it was all out-of-wack!!! They suggested 6# of CYU. I doubted the accuracy of the test and took a water sample to another pool service company and the results were drastically different. They suggested 11.5# of baking soda.
Not trusting either result I took a second sample to the initial pool service where I have been testing for the last month. And they ran it on a different machine and the results matched closely with the second service I took the sample to. All that said, I feel like I have trustworthy data to share and ask for your help. Data below are my current values and the ("recommended range") according to the testing company.
FC: 4.7ppm (1-5ppm)
TC: 4.7ppm (1-5ppm)
CC: 0 (0-0.9ppm)
pH: 6.7 (7.2-7.8)
Hardness: 277 (200-400ppm)
Alk: 5ppm (80-120ppm
CYU: 31ppm (30-50ppm) note my owners manual recommends 80ppm. The FC/CYU chart is 70-80 I think.
copper: 0ppm (0-0.2)
Iron: 0ppm (0-0.3
Salt: 3500ppm (2800-3500ppm)
This morning after reading this site I turned the chlorinator off, turned the pump on high speed and started adding stabilizer/CYU in 2# increments. plan to add every 6 hours for a total of 6#. Wait a few days and retest. And then work on the alk levels.? or should I do both at the same time? My logic is change one thing at a time to keep track of the effects of the chemical added so I can understand better the changes that are occurring.
Also, plan on getting my own test kit.
Any and all advise is greatly appreciated,
Mark
FC: 4.7ppm (1-5ppm)
TC: 4.7ppm (1-5ppm)
CC: 0 (0-0.9ppm)
pH: 6.7 (7.2-7.8)
Iron: 0ppm (0-0.3
Mark
