Hello all,
I'm not new to pools, but I am new to taking care of the pool myself. I'm not sure I am doing this right. I also don't feel confident that I have correctly calculated the gallons in my pool. I came up with 15,795 gallons. I have a 15x30 pool that is about 3 feet 9 inches at the shallow end to 5 feet 1 inch at the deeper end, which is at about the 3/4 mark, with the remainder sloping back up to about 4 feet if that makes sense. Then a 5x7 spa that I measured at three feet 1 inch deep. Does that sound right?
I first tested with the TFP Pro test kit on Tuesday. The results I got:
8.5 FC
1.0 CC
8.2 PH
170 TA
650 CH
90 CYA
I added what the Pool Math app suggested, which was 36 oz of 7.5 percent bleach and 19 oz of dry acid. Pool looked nice and blue. Yesterday I did all the measurements again to double check myself and make sure everything was going in the right direction. Not really sure. I got:
6.5 FC
2.5 CC
7.8 PH
170 TA
600 CH
130 CYA Not confident about doing this test at all
93 water temp
.79 CSI
So the app suggested adding 194 oz of bleach (over a gallon!) and 20 oz of dry acid, which seems like a lot. I have not added that yet. Is that right? This seems like the pool will need tons of bleach each week if so? Also, the app says the .79 CSI suggests likely scaling. What do I do about that? Also, do you not record the yellow side of the PH test? Confused about there being a test that you don't "need" or record. If I need to add chlorine daily, does that mean I should also do the chlorine test daily? My family does swim most days in the summer.
Also, is there a post about all the stuff you need to do to maintain the pool outside of chemicals? For example, do I still need to brush and vacuum weekly if we have a pool robot? How does backwashing work and how often should that be done? We did just clean the filter. Are there other pool care things I am missing? Thanks for any help!
8.5 FC
1.0 CC
8.2 PH
170 TA
650 CH
90 CYA
6.5 FC
2.5 CC
7.8 PH
170 TA
600 CH
93 water temp
.79 CSI
