Greetings everyone!
I am experiencing some staining problems and hoping some experts can offer their opinions and advice.
I opened up the pool this year to a very noticeable stain ring around the pool where the water level would have been over the winter. This also happened last year too. I'm trying to figure out exactly what is going on here, so all input will be appreciated. Please see attached pictures of this stain ring.
A quick back history... We had our 50 year old pool (that we inherited when we bought our house a few years ago) plastered with Diamond Brite in mid September, 2019. The pool was fully sandblasted down to the original concrete (which I was told was Shotcrete), all cracks were filled-in and then it was bond-coated right before plastering. We also had the attached Spa I built plastered at the same time.
The pool is about 34k gallons, and the spa is about 1k gallons. I had 5k of water trucked-in to expedite the initial filling. The rest was from our city tap water. I added one or two bottles of Jack's Magic just because I read here on the forum that it is good practice in case there are any metals in the water. (Our city water has a low copper level on their reports, btw.) The pool filled-up with a greenish tint to the water, but the spa was great. I panicked and called the PB, who said that was normal for a first time fill. So I waited it out a few days and the water cleared up perfectly. I did everything needed over the next two months (perfect levels, brushing, vacuuming, etc and closed in mid-to-late November, trying to give enough time for the new plaster. I closed everything at the right levels, and didn't add anything except maybe a bottle of Polyquat 60 but I am not 100% sure on that. I have a gas heater hooked-up, but did not use it till the following year. I also have a SWG, but did not install it till the following year.
Over the winter, some of the water bags lost hold of the solid cover and it got slightly pulled into the pool. Some leaves, twigs etc. were in the pool when we opened it last year in mid April. The water was algae green which cleared up in a week with shock level chlorine, but the pool itself still looked great except for a stain ring more or less what I opened with this year. Also, there was a lot of scale all over the surface, and of course the pH was very high, which was understandable because it was just plastered.
I came to the conclusion (not sure if it was correct or not) that it was calcium scale staining. Mostly because I had no idea how that much metal would have gotten in the water so soon to be metal staining, and because the staining was only in a ring right where the water level would have been while the pool was closed, and not anywhere else on the pool surface. Also, neither Vitamin C tablets nor chlorine pucks had any affect on the staining.
So I simply maintained a target CSI of around -0.8 (keeping the pH close to 7.0) to help slowly descale the pool and increased the chlorine level to about 75% of shock levels to remove staining. I brushed the stain ring and the whole pool everyday. It took a good two months or so, but the staining completely disappeared. I then put all the levels back to target and kept them there till I closed the pool last year. I didn't do any special stain chemical treatments and I didn't add sequestering agents either. I didn't even think about that because I didn't think it was even metal staining; rather I figured that the staining was organic-based, and that once all the staining was gone that it was a done deal. I installed the SWG and added salt after the stain was gone.
At the end of last year before closing, I made sure all levels were perfect, added a bottle of Polyquat 60 and closed her up.
This year was basically a repeat of last year. But I didn't want to take 2 months again to get rid of the staining. Plus I'm not 100% sure it is/was organic scale staining, so after some reading I did the Metal Magic sponge test which worked amazingly and completely removed the staining within 5 minutes. I then followed it up with a Metal Magic treatment. I only used 4 bottles, which was what was described for light staining for my size pool. I thought that would be enough because of how fast it removed the stain with the sponge test, but it only removed about a 1/3 of the staining. I did another treatment, and I'm at about 2/3 reduction in staining.
At this point I thought it would be completely gone. I used one of the stain ID kits.to see if I could see what the staining truly is because I'm not so sure what it is now. Iron had no effect, but the Copper & Scale test worked best. So I guess it's copper, or copper & scale, or scale with organic stains embedded in it like I've been suspecting this whole time.
Just out of curiosity, I did a sponge test with muriatic acid. I soaked a sponge and rubbed it on the stain on the wall and it came right off in seconds. Next, in a different area, I rubbed a chlorine puck on the stain, but that didn't make any difference. So I decided to leave the puck on the stain for a while. Well, I forgot to take it out a few minutes later and it sat overnight. When I remembered and took it out in the morning, the majority of the stain was still there, but a ring of staining was removed where the outside of the puck was touching the Diamond Brite plaster finish. Lastly, I just noticed these dark bumps appear here and there, but only on the stain ring area.
So, sorry for the insanely long post, but any thoughts?
