just installed a new Jacuzzi pump in replacement of my old Pentair Whisperflo. There are few mechanical things that worry me.
1) air bubbles at all pressure side eyeballs outlet
2) dripping slow at the waste port regardless where the position of the of diverter valve. I currently set it at re-circulation position.
3) I hear air hissing sound if I set the diverter valve position at filter and water dripping come out at waste port at a stream drip. is this mean the gasket inside the diverter valve gone bad? or something else?
3) Water leak at the diverter valve pipe plumping and at the off-line chlorinator connection point (known since last year). how do I patch these leaks? especially at the pvc join at diverter valve.
4) when I turn the pump off, the water level in the pump basket dropping down slowly (visually see it drop). if the system is tight the water level should not drop right? Last year, with a know leak at the chlorinator, the old pentair whisperflo water in the basket not drop when I turned off the pump. the different this year is new Jacuzzi pump and the hissing air and waster come out of the diverter valve waste port.
Video show these problems
IMG 17972 - YouTube Pump shutoff and something draining out
IMG 17961 - YouTube
IMG 17991 - YouTube Bubbles
IMG 17981 - YouTube
IMG 17921 - YouTube Diverter valve set at filter.
IMG 17951 - YouTube
What should I do about these mechanical problems?
thanks
Olivier
IMG 17961 - YouTube
IMG 17981 - YouTube
IMG 17951 - YouTube
thanks
Olivier
