Mid full drain and looking for refill balance info
Jfair9
Active member
Jul 19, 2021
40
Phoenix
I just started draining my pool this morning and hit has quite a bit to go. I'm looking for some guidance on how to rebalance the water after filling her back up. Will he making a trip to the store to grab necessary chemicals. Any insight or guides would be super helpful thx
How are your testing your water? Ideally that is using your own test kit, but please post up your pre-drain numbers and the numbers of your fill water.
You will for sure need chlorine and stabilizer to add to your pool once you refill. Given your location in the US, I suspect you have more than enough calcium in your fill water but we would need to see exact numbers to give guidance there and on the other metrics.
