- Dec 13, 2020
- 932
- Plaster
- Jandy Aquapure 1400
Can a Mastertemp expert please help me out?
My 7-year-old heater has been cranky for a while: randomly shutting down the gas with AGS and HLS errors, but then working okay again when restarted. We don't heat the pool. Just the spa when we want to use it. Maybe 20 times a year for a few hours. So the heater sits idle most of the time. I know that's not great for the heater, but there you go.
Over time it got worse. So I replaced AGS and HLS sensors and finally the thermal regulator. OEM parts. The old regulator was definitely stuck, so thought that was it.
But no joy. Tried again today and both AGS and HLS triggered after a running maybe 5 minute.
So looking at lots of TFP threads, it feels like this is a flow problem. My flow gauge says 50 gpm running the Intellifo at 2500 RPM and the bypass is in "no bypass" position. The book says minimum is 40, and the flow sensor has never triggered. For years this seemed fine.
With the heater bypassed, flow is much higher: about 82 gpm. There are some threads saying Mastertemps have a pretty high "head loss" so never thought this was a problem.
Since the family was wanting the spa heated today I tried turning the pump up to 3100 rpm and restarting. Yay. It got to 99F successfully. The flow is about 60 gpm. With the header bypassed, it's about 100.
So I am thinking something is wonky inside the manifold and I need to take it apart. Maybe the pressure bypass is broken? But I don't want to disassemble for no reason.
Any help? Thanks as always.
