I thought that maybe this would be an option, but I've searched online and haven't found anything about it. I'm guessing probably because it won't work
. I was thinking of using a chest freezer with a replacement thermostat that allows it to be controlled to a temp above freezing (that part is confirmed). Then cut a couple holes in it and coil return line coming from the filter in the freezer allowing the pool water to chill prior to exiting back into the pool. I figure I can coil 50' in a chest freezer, probably more). Would the water simply not be in the freezer long enough to make much difference? What if I filled the freezer with water to surround the pool return lines with cold water rather than air? Would I burn out my pump having all that return line? I live in AZ and just put in a smaller (9x18x52) above ground pool. I'm going to put a fountain on it and use some umbrellas, but I thought this freezer idea would make for a nice redneck pool chiller.
Thoughts?
Thanks!
Thoughts?
Thanks!
