Magnum Force V Series 2.7 HP Variable Speed Pump, need help, need all help please
Brentr
3,648
Jacksonville, FL
Hayward Aqua Rite (T-15)
Hi Guys, Gals and Industry experts, I am considering changing out my one speed pump and I have an opportunity to purchase a new never used Magnum Force V Series 2.7HP Variable Speed VMF-S2 pump for a good price from a seller. I am not familiar with this brand but the VS motor is a century V Green 270, model ECM27CU. I am wanting to know if it will interface with my GL-235 solar controller, so when it call for heat the pump will go to a higher speed. And any suggestions how to interface this with my Aquarite SWG also.
Thanks in advance for all suggestions and opinions. :cheers:
The motor has an auxiliary relay that can be used to turn on a 115/230V load at a preset speed. It could be used to control the SWG or setup a speed to run when the solar is enabled
The GL-235 has a 115-120V high voltage output. Do I just attach that to the relay?
