Low Pressure
GMTK
226
San Antonio
Noticed my waterfall from my spa in to the pool wasn't looking like it normally does. I check my filter housing and the pressure is reading about 5 psi, when 10-11 psi is normal.
Pool level is normal. Skimmer baskets are empty and I checked under them to make sure there was no debris. Cleaned all 4 filters. Emptied basket on the front of the pump. It's a two speed pump and yes it was in "high" and/or "normal" speed and not low speed.
Thoughts? I'm thinking maybe a return line to the pump is clogged, we've had a TON of wind and leaves in the pool.
