Loose aggregate on new WetEdge
shingles
0
272
Houston, TX
So the Polaris picked up some loose aggregate in the pool. It’s not a lot at all but just enough to see some in the muck. I assume through out normal brushing on a new finish some lose stone is bound to come off. The robot did not get dropped in the water until well after 30 days has passed. So the question is. At what point would one worry about any issues?
You will likely find plaster and pool build debris in your pump strainer basket. I found a chunk of PebbleTec plaster in mine the size of a 50 cent piece a few weeks in. A few pebbles from the plaster is nothing at all to worry about. You will continue to see some shedding for a few weeks and then it will settle down. Every once in a while you’ll see a pebble or two, no big deal.
