Hello! I will be buying an above ground pool from The Pool Factory and I have some questions with the products and set up. I will be doing a 24' round saltwater pool and through my research I see I should go with a Resin Composite wall as that is what is best with the saltwater. I have never had a pool before and this is all new to me.
Going through the customization options on the Pool Factory:
Is it worthwhile to upgrade the liner from a 20 gauge to a 25, 30, 35 or even 40 gauge?
The filter system. This I need the most help with. Cartridge, Sand or D.E. If it matters I live in North New Jersey and there will be no trees around in the area of the pool. I would prefer a filter system that is less maintenance and more dummy proof but also less expensive over time.
Same thoughts/preferences with the Saltwater Systems. I see a Drop In, Return Jet and Hard Plumbing.
Would I be better in buying all these products straight from Pool Factory or will local stores possibly have the filters and saltwater systems cheaper? Thanks for all the help, Much appreciated!
