So happened on a thread on bonding. Realized my light niche isn’t bonded back to the equipment pad. However it is grounded via a copper rod driven into the ground by the junction box off the deep end. Should I also run a bond wire back to the equipment?
Also, in terms of grounding does the equipment need to be done so via a rod, or is the ground wire back to the feeder panel adequate? Just checking.
