Hello all,
I’ve got an older pool (1990s) with a vinyl liner from 2019. The light niche ring has corrosion on it, and the light itself has been malfunctioning. There is not enough slack in the cord to access the light niche without draining the water, so the pool guys drained the water down below the niche. Both the pool company and the electrician said it was necessary because the prior installers did not do the wiring right inside the niche.
They warned me about draining the pool that much, and know it is a risk, however I don’t know how much of a risk it is. The electrician is planning to come out early next week to do the repair, so if I refill it immediately will that avert the risk?
The pool is covered and winterized at this point, and I plan to check it daily for signs of problems. Anything else I can do?
Jeff
Jeff
