Hey folks....Im in Northern NJ, and I just opened my pool a little early in the season this week. The company that built it opened it for me while I wasnt home but they left a note that they shocked it too. I have run my filter for the last 48 hours, backwashed, reloaded DE and did several Pressure side vaccum cycles and the pool is finally clear, clean and visibility looks ready for the weekend. However, My water chemistry now needs to be properly balanced
I usually maintain my own water balance and do a pretty decent job with all the help from everyone here on this forum...so Im coming back to ask for some simple strategic advice of what I should attack first to get my numbers in check....I've done this before but its been a while and I dont recall the order in which I realigned my chemistry last season. So if any of you can provide some simple advice on how to attack, I'd appreciate it....thanks
Tested using the TFT 100 Kit
FC 27.5
CC .5
PH 7.8
TA 200
CYA 30-40 (approx)
Also quick question....I took these readings after the pool was already shocked and the Chlorine levels where very high (see above) Does that in any way skew the accuracy of the numbers I have taken?
Any assistance you can provide would be appreciated ....thanks
My sig is up to date for my pool specs (except for the water chemistry...those are last years numbers
FC 27.5
CC .5
PH 7.8
TA 200
CYA 30-40 (approx)
