Hey there.
Curious as to why I keep getting scale build up on the output "grate" side of my Jandy Aquapure PLC1400 cell after only about 2-3 weeks of running. It doesn't seem to build up on the face of the plates themselves but rather just the end-grate that holds the plates in place. Same thing was occurring on my old SWCG before it died after 4 years. I am able to use a plastic utensil to break off the scale relatively easy, without needing any acid, but if it goes too long I'd imagine it will start impeding flow.
I will get some proper CSI numbers next week, but the last time I measured, these were what I remember (any number without a "~" prefix is up to date and accurate):
water temp: 90. Technically the vast majority of the water is 87 degrees, but when running most of the day at 1600rpm with the pool cover closed, most of the water that goes through the pump is from the top layer and that combination of water is 90 degrees.
pH: ~7.4-7.8
TA: ??
Calcium hardness: ~350-500
salt: ~3600
fC: 5 (SWCG is set to 60%, which keeps the fC level stable, but currently fC=5 is probably a little high and needs to be more like fC=3)
CYA: ~80-90
Borate: 0
TDS: ? (water was complete refill 4.5 years ago)
I run the pump at 1600rpm (1200rpm will have low flow error) from 6am to 5pm, with the exception being a 1hr run from 12pm-1pm @2850rpm and a 30min run from 4:30-5pm@2850. Well, the solar heater might kick on for a couple hours in the morning at 2200rpm, but by noon the pool is at above set temperature. Oh, and the SWCG is plumbed in a vertical configuration so the output is at the top, then the piping does a u-turn and goes back to the ground and then the piping goes back vertical a foot to the return valve before going back down underground (I can share a photo if necessary)
I am curious why the SWCG output grate is seeing the build up. Could it be the positive CSI? But why would it not be on the input grate or the cell plate faces themselves? If it is the positive CSI, how would I get it to be slightly negative without a refill of the pool, especially since my tap water is probably 250-350 calcium down here in San Diego, CA. I am afraid even a partial refill won't help significantly. I supposed I could add acid (to reduce the pH) twice a week instead of 1 a week, to keep the pH and TA consistently on the lower end of the range (though I might be talking out of my Rear with that).
Anyways. I am including a before and after cleaning of the SWCG. Is there any other information I am leaving out?
Thanks!
pH: ~7.4-7.8
TA: ??
salt: ~3600
CYA: ~80-90
Borate: 0
Thanks!
