We have always wanted a pool however our property is all hillside located in southwestern PA and we never though it was possible. Recently discovered semi-above ground or hybrid options. Would like a 15x24' oval/grecian or rectangle size and shape. Photos of location below.
1. Would you advise installation on this level of grade? The white stake is 54" from the ground and 20 feet from patio edge. Patio is 24' and would like long edge of pool to run parallel. That side would be buried completely with hillside tapering down two short ends. Long side opposite of patio would be exposed above ground.
2. Is it feasible to do a DIY build with some help with excavating and electrical? I know everyone's skill differs and it is impossible to say, "Sure you can do it". We have done many DIY projects inside our home, however we are not professionals. I've read that french drain is wise to divert water from walls on buried side. Also a slurry mix of fill between patio and pool when draining and liner replacement is necessary.
3. Recommendation for brand and type? We've been researching the following: Would you add or remove any options from this list?
- Buster Crabbe Aquasport 54 aluminum 4" panels
- Doughboy Hydrosphere
- Alligator Group Hercules
- Radiant Pool foam insulation between aluminum panes
