I’m getting ready to prep my pool for closing. I’m trying to decide if I’m going to add polyquat before closing like I usually do or close at SLAM level this year since the water temperature is down to 60 degrees already. The company who installed the pool 20 years ago says that closing at SLAM level with a FC of 16 ppm would be harmful to the gelcoat since FC levels will remain high all winter. The gelcoat in my fiberglass pool has been chalking terribly this year and the calcium level is only 200 so my pool pro thinks that the chalking is due to deteriorating gelcoat and not scaling and it will need refinishing in a few years. I would like to postpone the refinishing as long as possible since it is very expensive so should I follow his advice and use polyquat? I haven’t had much success with polyquat in the past and usually have to spend a week or more doing a SLAM so I wanted to try closing at SLAM level instead this year if it wouldn’t harm the gelcoat by doing this.
