- May 4, 2022
- 15
- Fiberglass
- Hayward Aqua Rite Pro (T-15)
Ok, first post, so be patient
So, I have iron staining in my pool. Pretty sure it came from using Clorox Fast Dissolving pool salt though I'm not prepared to declare it definitively.
I have the stains mostly lifted with AA and presently have Jacks Purple Stuff as the sequestrant. While this is ok for the moment, I want to remove the iron long term. I also understand the most effective way to replace the water with iron-free water. However, I have an IronEater Air-Injection Fleck 5600-SXT filter with carbon media. I'd like to remove it with the filter. I've setup and tested the general layout as such:
Submersible Pump -> Hose into Filter -> Hose out of Filter back to pool / Backwash line exiting to waste drain (not back in pool)
I spoke with the filter company tech support and they said it should work so long as I do the following:
Thoughts?
- Limit the GPM to 3, slower is better (I was at 5gpm)
- Manually close the line back to the pool during backwashing (I was)
- Backwash after every 500 gallons for at least 15 minutes with at least 5gpm
- They also noted the carbon would remove chlorine at first but eventually would stop, the iron trapping in the media would continue to work
- pH above 6.8 (mine is 7.4)
- Given I have sequestrant in the water now, is the air-injection enough to overcome the ion-bonding? I fear not...
- If not, would a hydrogen-peroxide injection tank oxidize the sequestered iron if injected on the way in the iron-filter
- Is there a reliable way to test the iron level in sequestered water using an at home test kit such as Taylor's Midget Comparer? I need a way to check the iron pre/post filtering.
Thoughts?
