Intex SWG issues
I have had the Intex SWG on a small 2,000 gallon pool for about a month or so now. I purchased a larger 1,000 gph pump to assist it. The SWG ran fine for a few days then it gave me a high salt warning. I drained 20% and added fresh water. I retested the water and the salt level was right in the middle. Then I received the code 92 high salt again. I tested the level and it was still right in the middle. I soaked the unit in vinegar per Intex instructions and nothing. They sent me a replacement Anode a few days ago. I swapped the Anode out and it ran perfect. This was about 5 days ago. Today I went to boost the SWG and it started giving me the error again. My salt level is fine. I unplugged the unit for about 30 seconds and retried it. Same result. Any thoughts? I should clarify I am using the Aqua Check? Test strips.
Hey! Sounds to me like something is wrong with your generator. Have you tried contacting the store you purchased it from? Seems like they can help you being that the SWG is new. How far off are your strips reading? The Aqua check test strips may give you a ballpark figure, but they operate within a +/-200 ppm error of margin. The drop titration Taylor K-1766 is much more accurate and I use it along with my generator.
