Intex ECO20110-2 Sand Filter Salt Chlorinator Low Flow Code 90
texastail
6
Texas
Intex Krystal Clear
I have an Intex ECO20110-2 Sand filter with saltwater chlorinator. Not one single issue last, the first year in use. Yesterday I set the pump and filter system up because my water had a lot of gunk and I needed to get it shocked and vacuumed. Everything worked fine. Left it in full pump mode, with the chlorinator off, all afternoon and night. This morning I started vacuuming the gunk off the bottom and everything was fine. For a while. I noticed there was no suction and very little outflow. And then the Code 90, low pump flow light and beep. So far not a darn thing suggested by many has helped. Nothing. I've changed out the brand new sand. I've pulled the impeller. Checked for air. Turned skimmer on and off. NOTHING. I keep reading about a Low Flow Switch but nowhere can I find where it is located. I'm about ready to toss the whole Dang mess in the trash. PLEASE. ANY HELP??
Backwash your pump then rinse, maybe it'll get rid of the "plug" causing it..
