18X33X52" in boxes in the garage
Ground was not level at all so I dug out the high spot. Added "stone dust" to the low spots and ran plate compactor over as pictured. Now I'm within 3" or thereabouts from high to low.
Then it POURED so we waited a few days for it to all dry out. Now I put down the paver stones for the columns where they would go. I know which paver is on the highest spot. (Looking at this picture, it's at about 4:30 on the clock)
My plan is to add additional stone dust under every single paver, making every paver level to each other as well as adding where the rail will sit, all well compacted as I go. I plan on going around and around the racetrack many many times as I've read you can never spend too much time compacting..
Once I have what I'm calling the "racetrack" done, then I will fill in the pool area with additional stone dust to make it all nice and level like one big flat pizza.
I have a Gorilla Pad. Do you think I can put the pool up right off of the stone dust or do I need to add in a layer of sand? Thoughts? Comments? Opinions? Criticisms?
