Howdy from Houston
briangreul
49
Houston, TX
Hello all,
I'm in Houston, TX and have a ~10K/gal in-ground pool. It was in rough shape when I bought the house 8 years ago and it's currently looking as bad as I've ever seen it. I have a lovely crop of algae that defies everything I do to it. :(
My pool's redeeming feature is that it provides a stimulus to the equipment industry with annual purchases of equipment and chemicals. :(
It's also pretty to look at in the evening.
Small victories:
- Converted the niche light to LED and never looked back.
- Successfully figured out how to close the niche clamp with the minimum number of cusswords or lost hardware pieces.
- Replaced the 2 HP pump with a 1 HP pump based on actual calculations and a desire not hear an idling jet engine.
- Converted it from a suction side entertainment device to a Polaris 280 pressure cleaner.
- Rebuilt the Polaris 280 at least once. It's due for another upgrade and is lounging out of water until I get to it.
- Converted to a CircuPool SWG this year and ended my contributions to the chlorine tablet mafia.
- Installed CircuPool's vortex accessory and have been impressed with it.
- Installed "smart" timers that can be controlled through home automation and sold my Intermatic POS timers on eBay.
Past accomplishments:
- Rebuilt / Replaced DE filter twice before finally taking a hammer to it and throwing it away.
- Found and dealt with plumbing leak at skimmer while wondering how anything ever flowed through the pipe because it was kinked.
- Installed a Hayward cartridge filter.. but it's on my list next to Algae as things that require constant attention.
Current Issues:
- Algae
- Water chemistry
- Excessive filter maintenance. I've not had good luck with "washing" the cartridge filter.
Future Issues:
- Pool needs replastering (it sort of needed it 8 years ago..... it really needs it now)
- I'd like a pool heater (but not until the chemistry issues are solved)
- Next pool pump will probably be a VFD equipped pump (also hyped as a smart-pump).
Welcome to TFP! :wave: You've been busy. :) Remember to follow the SLAM Process to completely eradicate algae, and visit/save our Pool Care Basics page for all things TFP. If you have any questions let us know. Enjoy the forum. :swim:
Yea, I posted in the test/balance just now. :). A SLAM is on the agenda, but I think I need to get a handle on the water chemistry first otherwise the chlorine isn't going to be able to do anything... which is part of the current problem.
I'm thinking of moving to a sand filter as well. I'm dreading scrubbing the pool and having to clean the cartridge filter every hour or so while I'm doing it. The cartridge is great performance wise, but a nightmare to keep clean/flowing if I scrub the pool.
Pros & Cons for sure. Water restrictions might play a part in your decisi0on based on backwashing, but otherwise many people like sand. Cart filters are very popular as well. I'll take a look at your algae thread as well.
