- Sep 28, 2016
- 58
- Vinyl
- Pentair Intellichlor IC-40
I have a pool slide that leaks from the middle joint. I put silicone caulk to prevent the leak last year but it started leaking again this year. There is a slight crack in the upper half of the pool slide where it meets the lower half. Can I caulk over the previous caulking or do I need to remove the old caulk 1st and recaulk? Is there a better way of stopping the leak?
How to stop pool slide leak? - Album on Imgur
