How to get rid of the delay when switching from spa to pool mode
Jul 26, 2016
58
Little Elm, TX
I have the Jandy epump with the Aqualink RS controller. When I switch it from pool mode to spa mode, it goes instantly. However when I try to either switch from spa mode to pool mode, or turn the filter pump off while in spa mode, the controller starts flashing ***'s and says the pump will turn off (or switch over) after delay. The delay seems to be some random amount of time between 5-15 minutes.
I can't see any purpose in this delay. Does anyone know why this delay exists? If it can switch from pool to spa instantly, it should be able to switch back instantly. Is there any way to eliminate or significantly reduce the delay?
