I just installed a new hot tub with a Gecko IN.YJ-2 controller and it trips the GFCI breaker immediately.
I have quadruple checked the wiring, the terminals screwed down tightly, etc.
Troubleshooting I found that if I remove the black lead (one of the hot leads) at the tub the GFCI does not trip. Nothing else prevents the GFCI from tripping.
I believe the unit is set up for 240V by default. Terminals show LINE1, NEUTRAL, LINE2, GROUND (all are connected).
Anyone have any ideas?
Thank you!
Thank you!
