I purged with Ahhsome, drained and refilled my hot tub and after 1 week I still have not been able to lower TA. (FYI - I also use the floating frog)
Using TF-100: Same readings from the 2nd day after new fill to today.
Cl 0.5-1.0
TA 240
Ph over 8.2
The water is clear and clean looking with little to no foaming or staining.
Throughout the week I added Spapure pH down (1.5 lb container) - almost the entire contents and TA has not lowered.
Can high hardness be an issue? My fill water is a combo of well and water softener - we have very hard water with metals.
I used the PoolMath and it calculated the following results that should occur after adding dry acid:
Are there different types and potencies of dry acid?
(I will not be using the Spapure chemicals after I use all of the bottles that came with the hot tub in May. Thanks to you I am using baking soda to riase TA when nec.)
Cl 0.5-1.0
TA 240
Ph over 8.2
