My wife has come across a recipe for home made laundry soap and dishwasher soap is anybody interested in us sharing it with them. Its amazing to read whats in it. It reminded me so much of the BBB pool method ....
It bubbles! It bubbbleslaunboy said:Another cheap cleaner is to pour some Baking Soda down your kitchen sink drain(or any other drain) then pour vinegar down after it. It's supposed to unblock minor clogs and clean the pipe in general.
HTH,
Adam
waterbear said:It bubbles! It bubbbleslaunboy said:Another cheap cleaner is to pour some Baking Soda down your kitchen sink drain(or any other drain) then pour vinegar down after it. It's supposed to unblock minor clogs and clean the pipe in general.
HTH,
Adam![]()
HTH,
Adam
If you follow this application with lots of HOT water it is even more effective! It will not work on big hairballs, tho!launboy said:Another cheap cleaner is to pour some Baking Soda down your kitchen sink drain(or any other drain) then pour vinegar down after it. It's supposed to unblock minor clogs and clean the pipe in general.
HTH,
Adam
TizMe said:I heard to use vinegar in the final rinse as well. We also have a front loader but there is a place to put fab soft but not sure if it will work the same or not?
There is another good drain cleaner that is very effective. It's called lye! Been used for years.sevver said:launboy said:Another cheap cleaner is to pour some Baking Soda down your kitchen sink drain(or any other drain) then pour vinegar down after it. It's supposed to unblock minor clogs and clean the pipe in general.
HTH,
Adam
I've tried that on the bathroom sink before, and it did not work. The best way to unclog a drain IMHO is to just take it apart and clean it out.
Another soapmaker!!!!!! I use only a mix of mostly olive oil and a small amount of tallow for laundry soap and NO coconut oil (for low suds) and keep a bit of free lye in it for better cleaning ability. I leave the washing soda out for this reason since the bit of free lye basically does the same thing.giulietta1 said:I make the laundry soap myself and grate it up, add the borax and washing soda, etc. It takes a slightly different recipe from bath/body soap; zero superfat for laundry soap. The soap recipe can be modified to make it low sudsing (or high).
