I'm in the process of rebalancing my pool for the first time after realizing (with the help of this forum) that the pool stores have no idea what they are doing and were wasting my time and money. Anyway, first issue was my CYA was through the roof. I finally got around to emptying about 50% of the pool and refilling. CYA is now between 50-60 which I think is about right for now.
I want to perform a SLAM to start things right again but at the moment my pH is well above 8.2 still. I've added nearly 40oz of 31.45% muriatic acid in the past 2 days. pH is still above 8.2. I'm assuming I need to add more muriatic acid until I can get this down to 7.2 as recommended in SLAM protocol. Does this make sense?
If I estimate the pH at 9 and a target of 7.2, PoolMath is suggesting another 51oz of acid.
Here are the test results from this morning: CL=0, pH=>8.2, FC=0, CC=.5, TC=.5, CH=250, TA=90-100, CYA=50-60, CSI=1.21
Any thoughts or recommendations are greatly appreciated!
