Hi all.
First time pool owner, and at the point where I need to close it. Have spent some time going over relevant threads and stickys on the forum, but still need some guidance. Hopefully someone can help.
The main question I have at this point is how to blow out the lines. The pictures show my setup. There is a DE filter. Two incoming lines - one from the skimmer, and one from the main drain. I currently have the skimmer valve turned off because the water is below skimmer level (but above return level). One outgoing line which goes back to two return inlets in the pool.
Based on reading some threads here, I concluded that I could get away with using a high power (6hp) shop-vac instead of spending a lot on a custom cyclone blower?
Now the question is what I should dismantle to blow into?
All this equipment is new to me and kinda in over my head (pun intended). Any help is greatly appreciated! Once I'm done, I suspect I will have another post asking about my safety cover (GLI ProMesh) installation
