Okay, starting to feel a little more comfortable about things so diving in a little deeper (no pun intended) to ensure I have everything set up as optimal as possible.
So would love some help digesting the info, and maybe any suggestions on my variable speed pump settings. Screen shots below.
Equipment is all Jandy, with iAqualink RS3 (I believe) for great remote access and config.
Pool is about 18-20K gallons (I need to dig for the actual number, but this is very close), and includes a large tanning ledge and a large spa. Min/max depth of pool 3.5' -> 5'.
Location is north texas / DFW area.
We have a gas heater, in-line chlorine (uses tabs, metal filter insert removed and plug added), large DE filter system, and a heat/cool pump.
We also have a Betta bot that does our skimming (and it's phenomenal, apologies to my wife for waiting so long to buy this).
Pump 1 is for my pool in general (Filtration), with a max speed of 3450, priming at 2500, for 3 minutes
Pump 2 is for my Waterfalls/Sheer Descent, Qty 3, 24" each (Aux Pump), with a max speed of 3560, priming at 2500, for 3 minutes
Question about basic setup:
1) Do these seem right? Should I be validating this with my pump settings, or assume (yikes) they are accurate?
My main pump is the one I'm curious more about:
By the way I read this, if the pool is in the mode listed in "Speed Label" column, then the pump runs at "Speed Setting". So if I'm running the Cleaner, the pump runs at 2750. Normal pool mode is 1750, spa mode is 2750 also for example.
Questions on this:
1) Does it make sense the pool is slower than the spa because it runs more of the time and this is for efficiency?
2) Is spa too high? Or is this higher to keep circulation higher and motion in the spa?
3) Heat options are slower - this is to move it at a reasonable rate - but why is Heat Pump higher? (Note Heat Pump is heat and cool both)
4) Cleaner is higher - is this to run more through the filter, even though the cleaner (Quattro Sport) has its own pump?
On related question:
5) How can I determine the best schedule as well?
- How long should the pump run daily for moving water purposes?
- How long should the cleaner run daily for the robot vac?
- Anything else I should update for the sake of either cleanliness or efficiency?
If I missed any important info, please let me know.
Thanks!
Questions on this:
Thanks!
