I am in the process of filling up my 12x24 doughboy with a deepend after doing a liner replacement. Everything was going well until I let the liner down for the final time and it set against the walls. It appears the the gladon original foam pool cove had a gap on the top and as the water filled the pressure pushed the foam core away from the wall on the backbends. As you can see in the attached pictures. I am not sure what I should do to fix this. I stopped filling with the water (only has about 12" in it) Thanks in advance
