Help finding replacement motor for Jandy Stealth Pro Series pump
jesse-99
724
Illinois
Jandy Aquapure 1400
I have (2) Jandy Stealth Pro Series pumps (model#SHPF3.0) for waterfall features. One pump works great, but the one pump has a really loud/noisy sound everytime it runs and sounds like its going to fail (so far so good though). I'm wondering if I can just replace the motor itself? I'm not having much luck figuring out the exact one to order however or the right part #?
This is the main pump itself...
This is the back end where the motor is....
Can someone help me figure out what I need or where to get it? (is it easy to replace?) These were probably installed back in around 2011 or so. I only run these 2 pumps for about an hour a day, so doesn't make much sense replacing the entire pump with some newer VSP setup (plus I already have 4 other VSPs which is all my Jandy iAqualink can use).
