Hi there!
My first in what I'm guessing will be a long list of questions.....We had the pool installed very late last year so only used it a bit. Even with the heater cranked up, swimming in November in Connecticut was novel yet uncomfortable.
My arch enemy seems to be the filter pump where the priming is supposed to take place. I had some issues but had come to terms with it last year but that was before the slide was hooked up so I'm thinking that might be adding to my troubles. Everything has been running fine since it was opened a week or so ago until yesterday when I noticed a lot of debris in the pump filter. I turned everything off, took out the debris, cleaned the little basket, poured a bucket of water in, sealed it up tight and turned on the filter...now we can see air in the hose going from the pump to the filter, the pressure rises just a little bit and we have no suction in the skimmer and nothing coming out of the jets. I mention the slide because now there are 2 valves that we turn on and off if we want the water coming down the slide and I am worried that we've messed with them so the the water is not flowing correctly. We do have a service call but not sure when they will get to us. Is anyone able to tell by looking at these photos how the 2 red valves should be set when we do not want to use the slide? I "think" that the top one is supposed to be closed and the bottom one is supposed to be open but there are differing opinions within the fam
. And if these are or were set incorrectly, would that have had any impact on the pump not priming?
If not, then does it seem realistic that everything was running without issues and once I opened the filter it would suddenly have a leak or need a new seal? I really wish I had just left the debris in there!
So, nice to meet everyone and hopefully someday I will get to a point where I can help others instead of asking for help. I grew up always having a pool and some things are so much more complicated these days and other things are so much easier!
Have a great day! Kat
