- Aug 20, 2020
- 7,758
- Plaster
- CircuPool RJ-60
I have a 20 year old larrs lite heater I’ve been limping along the past year. I had it working at the end of last winter but when I went to turn it on again today it was not working due to a blown fuse. After replacing the fuse, it fired right up and I thought, great we can get some more pool use for a couple months.
Then I hear some clanging around in the pipes and see the pipes bouncing around with what’s sounds like rocks being pushed through the filter and see chunks of rusted metal in my salt cell so I powered off the pump and heater, removed and rinsed out the cell and all appears to be ok, except the heater.
obviously the heat exchanger went kaput and the heater is done for, but I’m wondering if there is usually some kind of bypass internally that lets the water avoid going through the heat exchanger? I’m wondering if I can leave the heater plumbing hooked up and off without worrying about more metal chunks breaking loose and getting into the plumbing. It stopped making the horrible noise when I turned the heater switch off so I suspect there’s something like a bypass.
