Finally have a contract for a pool this April. It will be small 10X20 vinyl inground. average depth 4.5 ft. approx 6500 gallons, 200 sqft surface area. My house faces east . Pool will be right along side the back of the house, it will get very little direct sun due to the house and trees at the back of the small lot. I will be using the same contractor as my last pool. he does excellent work and stands behind it. He will be using heyward products, 1hp varible speed pump , aqua rite scg, sand filter. He doesn't have alot of call for heaters here, and couldn't offer much advice on brands or type. I have a heat pump already for the house. I also have natural gas for hot water and fireplace. I'm looking for help with choosing a heater to extend the season, not for year round swimming as it gets pretty cold here from jan to march. I would have to have a gas person run about 30 ft of pipe to the heater and connect it if I went the gas route. Poolman will install the heater of my choice, I'm assuming the electrical subcontractor would connect a heatpump if I went that route. I'm looking for affordability and dependability. KWH cost is 11 cents. Natural gas is 1.24 per therm. TIA
