So I have come to the first divergence in the data. As I prep for the testing and balancing of the chemicals - I ran into this.. dilemma.
the TFPC method states (taken from the Water Balance for SWG's)
FC 4-6 ppm
PH 7.2-7.8
TA 60-80
CH 50-300 for vinyl (Do Not Add)
CYA 70-80
Salt 200-400 ppm ABOVE recommended optimum level
Borates 30-50 ppm (optional)
While most of these differ somewhat from what is below the most concerning is the Salt, the link above says "most" recommend range is 3000-3200ppm, from the details in the picture below the SWCG that I have recommends 3500 - 4500ppm. I surmise that the TFPC is a specific balance of proven practices that hence provides some deviations from what "manufacturers" recommend and what practicality actually prove. But the level if I heed the TFPC method for Salt would be some where between 3900 - 4900ppm Salt..
Should I be maintaining in range of the SWCG as it is already at the modified levels (3500 - 4500ppm) mentioned in the Water Balance guide - or should I modify above what is listed on the SWCG and be @ 3900 - 4900ppm Salt?
Photo of table on SWCG
FC 4-6 ppm
PH 7.2-7.8
TA 60-80
CYA 70-80
